[GRASS-dev] Updating colorrules.py
Mohammed Rashad
mohammedrashadkm at gmail.com
Thu Dec 20 02:45:22 PST 2012
updated the patch. PFA
Do you think its necessary to update the file in trac ?
On Thu, Dec 20, 2012 at 8:50 AM, Mohammed Rashad <mohammedrashadkm at gmail.com
> wrote:
> Hi Anna,
> Adding a check for ultimatelistctrl widget and if not available can be
> done. But remember using the old implementation will crash wxGUI.
> How about If no ultimatelistctrl is not available we can add a copy of it
> our own with a warning
> Btw, I dont have a source build of wxpython. This comes with Ubuntu 12.04
> LTS
> On Thu, Dec 20, 2012 at 4:56 AM, Anna Kratochvílová <kratochanna at gmail.com
> > wrote:
>> On Wed, Dec 19, 2012 at 4:39 PM, Mohammed Rashad
>> <mohammedrashadkm at gmail.com> wrote:
>> > Hi All,
>> > gui/wxpython/modules/colorrules.py, providing inteface for setting
>> > colortable for raster and vector.
>> > As I reported on trac[1] several weeks ago there is a bug in the code
>> which
>> > happens if no. color rules for raster map is big (eg: 32763 This for
>> > nc_spm_08/landsat 4,3,2 color composite) . This will result in crashing
>> the
>> > whole wxGUI!
>> > The problem is for each rule colorrules.py create a checkbox,textCtrl
>> and
>> > ColorSelect.
>> > Creating these widgets will hangup the UI.
>> > A solution is to use a list control agw provides one such thing called
>> > ultimatelistCtrl.
>> > I had updated the colorrules.py and made a patch for it. Anyone Please
>> > review and update the file
>> Hi Rashad,
>> I can't even test your patch at the moment because UltimateListCtrl is
>> not supported in wxPython 2.8.10.1 (which is installed on my
>> computer). It seems that it is available from 2.8.11, however in the
>> grass requirements, there is wxPython >= 2.8.1.1. I agree that this
>> one is pretty old but still we must decide if it is worth changing the
>> requirements. I think that the version I have is still used a lot so
>> we should support it. You are using this widget to show the color I
>> suppose. I am not aware of any other good solution. Maybe you can a
>> condition on wxPython version and if it is high enough use this
>> widget, otherwise use the current implementation?
>> Anna
>> > PFA patch
>> > [0] http://trac.osgeo.org/grass/ticket/1816
>> > Regards,
>> > Rashad
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
> Rashad
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121220/e0abe3d8/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121220/e0abe3d8/attachment-0001.obj>
