[GRASS-dev] [GRASS GIS] #1841: segmentation fault in v.patch
trac at osgeo.org
Fri Dec 21 01:56:18 PST 2012
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: invalid | Keywords:
Platform: Linux | Cpu: x86-64
Changes (by pertusus):
* status: new => closed
* resolution: => invalid
Comment:
I made no change in the code. However, after I did a make clean, a build
and a reinstalled and it does not segfault anymore. So it does not look
like an issue in grass code, sorry for the noise.
I have no precise idea on what could have caused that. One hypothesis may
be prelink with randomized addresses, but that seems unlikely as both the
executable and the libraries are in places where prelink should not
venture according to what I understand about prelink configuration.
Another possibility could be that a partial build of the grass libraries
is not enough to get things right, you have to relink all the executables
that depend on the libraries and it is not done automatically? I just
checked that executables are not relinked when a library dependency is
rebuilt, but I am not very convinced that this explains anything. This
goes against all I know about binary compatibility.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1841#comment:2>
