[GRASS-dev] Grass7 GUI compilation failed
Rashad M
mohammedrashadkm at gmail.com
Sat Dec 29 08:27:14 PST 2012
grass7.0 fails compilation at first and continues only after setting
PYTHONPATH.
This becomes a routine for recompilation. Is there any work around to
automatically pickup wxPython?
Here is my error log:
Started compilation: Sat Dec 29 21:46:17 IST 2012
Errors in:
/code/grass/grass70/gui/wxpython/animation
/code/grass/grass70/gui/wxpython/mapswipe
/code/grass/grass70/gui/wxpython/gmodeler
/code/grass/grass70/gui/wxpython/rlisetup
/code/grass/grass70/gui/wxpython/psmap
/code/grass/grass70/gui/wxpython/dbmgr
/code/grass/grass70/gui/wxpython/vdigit
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sat Dec 29 21:53:10 IST 2012
wxpython is installed from ubuntu repos. so its in the default path
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121229/952e8c16/attachment-0001.html>
