[GRASS-dev] To --enable-64bit or not to?
Markus Neteler neteler at osgeo.org
Sun Dec 30 05:15:19 PST 2012
On Sun, Dec 30, 2012 at 1:51 PM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> GD Day Devs!
> Configuring with --enable-64bit results in (working on Kubutnu 12.10, 64 bit
> currently):
This is what Glynn said:
On Sat, Dec 19, 2009 at 6:55 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Isaac Ullah wrote:
>> My configure options for
>> grass have 64-bit enabled, so shouldn't that set it up to look for all
>> 64-bit architecture?
> AFAICT, the --enable-64bit configure switch only affects AIX, HP-UX,
> IRIX, and Solaris; it has no effect on Linux.
So, IMHO when you are on a 64bit Linux box, it will generate 64bit GRASS
anyway.
Markus
