[GRASS-dev] grass-dev Digest, Vol 82, Issue 57
Rashad M
mohammedrashadkm at gmail.com
Mon Dec 31 19:23:42 PST 2012
Did you tried new grass python API?. Before that could you tell what error
you are getting?
[0] http://code.google.com/p/pygrass/
[1] http://www.ing.unitn.it/~zambelli/projects/pygrass/
On Mon, Dec 31, 2012 at 7:14 PM, Brian Sanjeewa Rupasinghe <
jinkabs at gmail.com> wrote:
> Hi,
> Actually my requirement is to run Python script outside GRASS Python
> shell. For this i tried connecting to GRASS outside with Python following
> the GRASS-wiki instructions, but failed. Then i tried to connect to GRASS
> with OGR Python bindings, it too failed because gdal_grass plugin provided
> in OSGEO4W does not install in GRASS (they are considered obsolete in
> OSGEO4W). However i installed gdal1.6_grass with stable release of GRASS
> 6.4.3 (run with gdal latest version 1.9.x) in OSGEO4W. However, when
> checked for the installed packages, gdal_grass support is not provided. It
> is highly appreciated if it is included in the current OSGEO4W setup or any
> suggestion.
> Cheers, Brian
> On Sun, Dec 30, 2012 at 1:30 AM, <grass-dev-request at lists.osgeo.org>wrote:
>> Send grass-dev mailing list submissions to
>> grass-dev at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> grass-dev-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of grass-dev digest..."
>> Today's Topics:
>> 1. Re: GRASS Vector Support (J?rgen E. Fischer)
>> 2. Re: Grass7 GUI compilation failed (Rashad M)
>> ---------- Forwarded message ----------
>> From: "Jürgen E." Fischer <jef at norbit.de>
>> To: grass-dev at lists.osgeo.org
>> Cc:
>> Date: Sat, 29 Dec 2012 17:42:00 +0100
>> Subject: Re: [GRASS-dev] GRASS Vector Support
>> Hi Brian,
>> On Sat, 29. Dec 2012 at 10:58:19 +0530, Brian Sanjeewa Rupasinghe wrote:
>> > I need to automate some GRASS functions in my research work. If there
>> is a
>> > possibility to build gdal_grass plugin for Windows it is highly
>> > appreciated. Even the Python scripts that call GRASS functions from
>> > outside for MS_Windows do not connect with GRASS even though the
>> > instructions provided in the GRASS wiki is followed. I have posted this
>> > problem in grass-windows forum and finally advised me to bring the
>> problem
>> > down to grass-dev list.
>> And you are positive that the GDAL plugin would help? The above
>> description
>> sounds like a more general problem and I don't see any connection to the
>> missing plugin at all.
>> Does GRASS itself need the GDAL GRASS plugin at all?
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> http://www.norbit.de
>> committ(ed|ing) to Quantum GIS IRC: jef on
>> FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> From: Rashad M <mohammedrashadkm at gmail.com>
>> Cc:
>> Date: Sat, 29 Dec 2012 23:55:17 +0530
>> Subject: Re: [GRASS-dev] Grass7 GUI compilation failed
>> here is output from v.digit
>> make
>> ml
>> make[6]: Entering directory `/code/grass/grass70/gui/wxpython/vdigit'
>> GISRC=/code/grass/grass70/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
>> GISBASE=/code/grass/grass70/dist.x86_64-unknown-linux-gnu
>> PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:$PATH"
>> PYTHONPATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
>> LD_LIBRARY_PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:"
>> LC_ALL=C
>> /code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit
>> --html-description < /dev/null | grep -v '</body>\|</html>' >
>> g.gui.vdigit.tmp.html
>> Traceback (most recent call last):
>> File
>> "/code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit",
>> line 39, in <module>
>> import wx
>> ImportError: No module named wx
>> make[6]: *** [g.gui.vdigit.tmp.html] Error 1
>> rm g.gui.vdigit.tmp.html
>> make[6]: Leaving directory `/code/grass/grass70/gui/wxpython/vdigit'
>> make[5]: *** [guiscript] Error 2
>> On Sat, Dec 29, 2012 at 9:57 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>> grass7.0 fails compilation at first and continues only after setting
>>> PYTHONPATH.
>>> This becomes a routine for recompilation. Is there any work around to
>>> automatically pickup wxPython?
>>> Here is my error log:
>>> Started compilation: Sat Dec 29 21:46:17 IST 2012
>>> Errors in:
>>> /code/grass/grass70/gui/wxpython/animation
>>> /code/grass/grass70/gui/wxpython/mapswipe
>>> /code/grass/grass70/gui/wxpython/gmodeler
>>> /code/grass/grass70/gui/wxpython/rlisetup
>>> /code/grass/grass70/gui/wxpython/psmap
>>> /code/grass/grass70/gui/wxpython/dbmgr
>>> In case of errors please change into the directory with error and run
>>> 'make'.
>>> If you get multiple errors, you need to deal with them in the order they
>>> appear in the error log. If you get an error building a library, you will
>>> also get errors from anything which uses the library.
>>> Finished compilation: Sat Dec 29 21:53:10 IST 2012
>>> wxpython is installed from ubuntu repos. so its in the default path
>>> Regards,
>>> Rashad
>> Regards,
>> Rashad
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130101/5aea4622/attachment.html>
