[GRASS-dev] Re: GRASS 6.4.2 release
Helena Mitasova
hmitaso at ncsu.edu
Sat Feb 4 22:40:43 EST 2012
everything seems to be working here as well, except for a small issue just found by a student in wingrass
and confirmed in freshly compiled release on mac:
when saving image from map display that includes scale and legend, everything is saved correctly
when the default setting is used,
but when a template (pre-set image size) is used scale and legend either is not included
http://skagit.meas.ncsu.edu/~helena/grasswork/saveimg_test4.png
http://skagit.meas.ncsu.edu/~helena/grasswork/saveimg_test5.png
or it is not scaled properly
Helena
On Feb 4, 2012, at 4:32 PM, Helmut Kudrnovsky wrote:
>>> I would suggest to postpone final release for few days due to recently
>>> introduced switch from Python 2.5 to 2.7 in OSGeo4W framework.
>> I would raise discussion about releasing 6.4.2. No blockers reported
>> [1], no other critical bug reported related to py2.7. I would vote for
>> releasing 6.4.2 in few next days.
> tested a lot wingrass here on my winvista32-box with python 2.7., works
> quite nicely and a lot faster than with python 2.5.
> +1 for releasing it soon.
> Helmut
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-6-4-2-release-tp3991919p4365560.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
