[GRASS-dev] Re: [GRASS GIS] #587: svn versions should better
reflect svn rev
trac at osgeo.org
Sat Feb 4 23:11:15 EST 2012
#587: svn versions should better reflect svn rev
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: reopened
Priority: normal | Milestone: 6.4.2
Component: Default | Version: svn-trunk
Resolution: | Keywords: g.version, configure
Platform: All | Cpu: All
Changes (by hamish):
* status: closed => reopened
* resolution: fixed =>
Comment:
g.version in 6.4.2rc3 reports:
GRASS 6.4.2RC3exported (2012)
because include/Make/Grass.make has:
GRASS_VERSION_SVN = exported
(`svnversion`: "If invoked on a directory that is not a working copy, an
exported directory say, the program will output 'exported'.")
suggested patch:
Index: configure.in
--- configure.in (revision 50554)
+++ configure.in (working copy)
@@ -128,6 +128,9 @@
AC_PATH_PROG(SVN_VERSION, svnversion, no)
if test "$SVN_VERSION" != "no" ; then
GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+ if test "$GRASS_VERSION_SVN" = "exported" ; then
+ GRASS_VERSION_SVN=
+ fi
fi
AC_SUBST(GRASS_VERSION_FILE)
todo: should `g.version -g` revision= report blank or just not be printed
at all?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:63>
