[GRASS-dev] [GRASS GIS] #1565: wxGUI: command console with no map
display open causes error
trac at osgeo.org
Mon Feb 6 00:26:42 EST 2012
#1565: wxGUI: command console with no map display open causes error
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: command console | Platform: Linux
Cpu: x86-64 |
if you close all map display windows so you only have the layer manager
open, switch to the command console tab, and run 'v.info roads' or
'r.univar elevation.dem' etc the module runs fine but an error is printed
after it:
File ".../svn/relbr_6_4/dist.x86_64
-unknown-linux-gnu/etc/wxpython/gui_modules/goutput.py",
line 789, in OnCmdDone
display = self.parent.GetLayerTree().GetMapDisplay()
-unknown-linux-gnu/etc/wxpython/wxgui.py", line 441, in
GetLayerTree
return self.curr_page.maptree
AttributeError
'NoneType' object has no attribute 'maptree'
thanks,
Hamish
ps- in the grey bar between the top output pane and the bottom input pane,
could there be some text like "Enter command below:"? otherwise new users
just see a bunch of empty white boxes and don't know where they should
click. 6.4.1 had some "Cmd> " text to the left of the input box which
helped as a cue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1565>
