[GRASS-dev] Re: [GRASS GIS] #1217: d.vect -a flag locks up the wxGUI on windows (was: d.vect -a flag crushes fro windows 64 bit)
GRASS GIS trac at osgeo.org
Mon Feb 6 07:11:13 EST 2012
 Reporter:  RenatoMacciotta   |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.3
Component:  wxGUI             |     Version:  svn-develbranch6
 Keywords:  d.vect, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32            |
Changes (by hamish):
  * component:  Default => wxGUI
  * platform:  Unspecified => MSWindows XP
  * version:  unspecified => svn-develbranch6
  * milestone:  6.4.1 => 6.4.3
  * keywords:  => d.vect, wingrass
  * cpu:  Unspecified => x86-32
Comment:
 I can reproduce this in a recent nightly build of standalone wingrass
 6.5svn on XP 32bit.
  * start up the wxgui in spearfish
  * add the vector fields map to the layer manager, but don't press ok yet
  * go to the colors tab and select the -a flag but don't add a RGB column
 name, just press ok
  * endless hourglass lockup for wxGUI. (can forcibly kill it by clicking
 the window decoration "X" then [ok] to 'not responding..')
 and our old friend zombie dbf.exe is still lingering in the task manager
 even after grass exits. (see #1276)
 on linux I get this error message in the wxGUI output console:
 Command 'd.vect -a map=fields at PERMANENT' failed
 Details: DBMI-DBF driver error:
 Column 'GRASSRGB' not found
 Error in db_open_select_cursor()
 Color definition column (GRASSRGB) not a string. Column must
 be of form RRR:GGG:BBB where RGB values range 0-255.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1217#comment:2>
