[GRASS-dev] Re: [GRASS GIS] #961: WinGRASS-6.4.0SVN-r40852-1 installs GRASS, but it doesn't run
GRASS GIS trac at osgeo.org
Mon Feb 6 08:12:21 EST 2012
 Reporter:  stoyan                     |       Owner:  stoyan
     Type:  task                       |      Status:  assigned
 Priority:  normal                     |   Milestone:  6.4.0
Component:  Installation               |     Version:  6.4.0 RCs
 Keywords:  winGRASS, problems, start  |    Platform:  MSWindows XP
      Cpu:  Unspecified                |
Comment(by hamish):
 the symptom sounds like the classic missing dll problem (but which one?).
 try installing the Microsoft .net Frameworks and see if it helps. see also
 #1354, #1428, #1450
 http://grass.osgeo.org/wiki/WinGRASS_Current_Status#XP.2F2000
 > "Copy to C:\Program Fies\GRASS-64-SVN\msys\home\C:\Documents and
 Settings\Stoyan"
 do you still see that bad path name from the installer script?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:20>
