[GRASS-dev] Re: [GRASS-user] how to import NetCDF data??
Michael Barton
Michael.Barton at asu.edu
Wed Feb 8 12:05:26 EST 2012
Lack of NetCDF support would be a problem for sure. We wondered about that. Jennifer is trying on Windows and I'm on a Mac.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 8, 2012, at 9:16 AM, Kirk Wythers wrote:
Michael,
I could not open the file in GRASS either. I have attached the errors I got. They look like the same that you were describing (I tried both with and without the -o flag). I did however remember the work around I used, which was to:
1. import the .nc files into MATLAB
2. Export as GeoTIffs
3. Read the GeoTiffs into GRASS
This made sense for me partly because I needed to aggregate daily values to monthly means which I did in step 1, but then never thought much more about why I couldn't import directly into GRASS . Your problem motivated me to look into why I needed this workaround in the first place (which is not much of a workaround unless you have access to MATLAB)… which appears to be that my gdal does not have GMT/netcdf support either (as Markus pointed out yesterday). I am also using WIlliams binaries and frameworks.
I agree that more detail in the wiki would be helpful, but I think the first step is to compile to update gdal with GMT/NetCDF support. Perhaps William would be interested?
GRASS ERRORS:
GRASS 6.4.1 (latlon):~ > r.in.gdal input=~/Desktop/ppt_SRESA2_mid_annual_down_anomaly.nc output=ppt_SRESA2_mid_annual_down_anomaly
ERROR: Projection of dataset does not appear to match current location.
Location PROJ_INFO is:
proj: ll
datum: nad83
ellps: grs80
towgs84: 0,0,0,0,0,0,0
no_defs: defined
Import dataset PROJ_INFO is:
cellhd.proj = 0 (unreferenced/unknown)
You can use the -o flag to r.in.gdal to override this check and use
the location definition for the dataset.
Consider generating a new location from the input dataset using the
'location' parameter.
GRASS 6.4.1 (latlon):~ > r.in.gdal -o input=~/Desktop/ppt_SRESA2_mid_annual_down_anomaly.nc output=ppt_SRESA2_mid_annual_down_anomaly
WARNING: Over-riding projection check
WARNING: G_set_window(): Illegal latitude for North
On Feb 7, 2012, at 9:10 PM, Michael Barton wrote:
Thanks Kirk,
Here is a copy of the smallest file we tried. The big ones gave identical errors.
Michael
<ppt_SRESA2_mid_annual_down_anomaly.nc>
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Feb 7, 2012, at 11:49 AM, Kirk Wythers wrote:
I had to import a bunch of SSURGO NetCDF data not too long ago Michael (I was going back and forth with GRASS and MATLAB). I don't seem to remember having any trouble with gdal (which means that it must have worked!) Are you sure that the NetCDF is Lat Long?
What was your error exactly? Is the file too big to share? If not send it to me and I'll take a look.
Best,
Kirk
Kirk R. Wythers
Department of Forest Resources
University of Minnesota
St. Paul, MN 55108
tel: 612.625.2261
email: kwythers at umn.edu<mailto:kwythers at umn.edu>
On Feb 7, 2012, at 12:33 PM, Michael Barton wrote:
I'm trying to help someone at NCAR import NetCDF data and we keep getting an illegal north latitude error. Looking at the GDAL info, I think we need to specify some additional metadata, but the GDAL page stops short of giving an example of how to do this. Has anyone imported climate data this way?
Thanks
Michael
C. Michael Barton
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120208/7388b05b/attachment-0001.html
