[GRASS-dev] Re: [GRASS GIS] #1568: 'make install' results in an
installation dependent upon temporary build directories
trac at osgeo.org
Thu Feb 9 02:11:23 EST 2012
#1568: 'make install' results in an installation dependent upon temporary build
directories
Reporter: helsene | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: svn-trunk
Keywords: make install | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:3 hamish]:
> you need to edit that python script to set LD_LIBRARY_PATH to
> the right place.
correction: edit /usr/local/grass7.0.svn/.../grass70 (or is that in
/usr/local/bin/?) and change `gisbase` to /usr/local/grass7.0.svn
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1568#comment:4>
