[GRASS-dev] wingrass compilation simplifed
Sören Gebbert
soerengebbert at googlemail.com
Sun Feb 12 15:36:18 EST 2012
2012/2/12 <glynn at gclements.plus.com>:
> Martin Landa wrote:
>> http://wingrass.fsv.cvut.cz/grass70/logs/
> ImportError: No module named dateutil
> That's an add-on package:
Ooops,
i didn't realize that.
> http://pypi.python.org/pypi/python-dateutil
> http://labix.org/python-dateutil
> If it isn't practical to do without it, it should at least be listed
> in REQUIREMENTS.html.
Well, i really need it to parse date and time strings. But maybe i can
lend the parser code from the dateutil code?
> It's required for matplotlib, which probably explains why no-one has
> noticed the issue before.
This issue was recently introduced by me. I did not explicitly install
any Python add-on on my ubuntu system.
Hence, i have had the impression it is part of the standard Python library.
Best regards
Soeren
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
