[GRASS-dev] r.horizion bugfix and speedup
Seth Price seth at pricepages.org
Mon Feb 13 15:14:04 EST 2012
I made some tweaks to r.horizon/main.c to almost half its runtime and
remove a bug. By my tests, it's output is identical to before, but a 219
minute run has been reduced to 110 minutes. Mostly due to removal of
unneeded floor() calls. I could use some people to test and make sure I'm
not introducing any bugs, though.
Thanks,
Seth
--- main.orig	2011-08-14 06:32:49.000000000 -0600
+++ main.c	2012-02-12 19:20:15.000000000 -0700
@@ -144,12 +144,15 @@
 /* use G_distance() instead ??!?! */
 double distance(double x1, double x2, double y1, double y2)
+	double diffX = x1 - x2;
+	double diffY = y1 - y2;
     if (ll_correction) {
-	return DEGREEINMETERS * sqrt(coslatsq * (x1 - x2) * (x1 - x2)
-				     + (y1 - y2) * (y1 - y2));
+	return DEGREEINMETERS * sqrt(coslatsq * diffX * diffX
+				     + diffY * diffY);
     else {
-	return sqrt((x1 - x2) * (x1 - x2) + (y1 - y2) * (y1 - y2));
+	return sqrt(diffX * diffX + diffY * diffY);
@@ -841,36 +844,28 @@
 int new_point()
-    int iold, jold;
-    int succes = 1, succes2 = 1;
-    double sx, sy;
-    double dx, dy;
-    iold = ip;
-    jold = jp;
+    int iold = ip;
+    int jold = jp;
-    while (succes) {
+    while (1) {
 	yy0 += stepsinangle;
 	xx0 += stepcosangle;
 	/* offset 0.5 cell size to get the right cell i, j */
-	sx = xx0 * invstepx + offsetx;
-	sy = yy0 * invstepy + offsety;
-	ip = (int)sx;
-	jp = (int)sy;
+	ip = (int) (xx0 * invstepx + offsetx);
+	jp = (int) (yy0 * invstepy + offsety);
 	/* test outside of raster */
 	if ((ip < 0) || (ip >= n) || (jp < 0) || (jp >= m))
 	    return (3);
 	if ((ip != iold) || (jp != jold)) {
-	    dx = (double)ip *stepx;
-	    dy = (double)jp *stepy;
+	    double dx = (double)ip *stepx;
+	    double dy = (double)jp *stepy;
 	    length = distance(xg0, dx, yg0, dy);  /* dist from orig. grid point
to the current grid point */
-	    succes2 = test_low_res();
-	    if (succes2 == 1) {
+	    if (test_low_res() == 1) {
 		zp = z[jp][ip];
 		return (1);
@@ -882,54 +877,44 @@
 int test_low_res()
-    int iold100, jold100;
-    double sx, sy;
-    int delx, dely, mindel;
-    double zp100, z2, curvature_diff;
-    iold100 = ip100;
-    jold100 = jp100;
-    ip100 = floor(ip / 100.);
-    jp100 = floor(jp / 100.);
+    int iold100 = ip100;
+    int jold100 = jp100;
+    ip100 = ip * .01;
+    jp100 = jp * .01;
     /*test the new position with low resolution */
     if ((ip100 != iold100) || (jp100 != jold100)) {
 	/* G_debug(3,"%d %d %d %d\n",ip,jp, iold100,jold100); */
 	/*  replace with approximate version
 	   curvature_diff = EARTHRADIUS*(1.-cos(length/EARTHRADIUS));
+	Code folded into the 'if' statement:
 	curvature_diff = 0.5 * length * length * invEarth;
 	z2 = z_orig + curvature_diff + length * tanh0;
 	zp100 = z100[jp100][ip100];
+	if (zp100 <= z2) {...
 	/*G_debug(3,"%d %d %lf %lf \n",ip,jp,z2,zp100); */
-	if (zp100 <= z2)
+	if (z100[jp100][ip100] <= z_orig + 0.5 * length * length * invEarth +
length * tanh0)
 	    /*skip to the next lowres cell */
-	    delx = 32000;
-	    dely = 32000;
+	    int mindel;
+	    int delx = 32000;
+	    int dely = 32000;
+		double sx = (xx0 * invstepx + offsetx) * .01;
+		double sy = (yy0 * invstepy + offsety) * .01;
 	    if (cosangle > 0.) {
-		delx =
-		    floor(fabs
-			  ((ceil(sx / 100.) - (sx / 100.)) * distcosangle));
+		delx = fabs((ceil(sx) - sx) * distcosangle);
-	    if (cosangle < 0.) {
-		delx =
-		    floor(fabs
-			  ((floor(sx / 100.) - (sx / 100.)) * distcosangle));
+	    else if (cosangle < 0.) {
+		delx = fabs((floor(sx) - sx) * distcosangle);
 	    if (sinangle > 0.) {
-		dely =
-		    floor(fabs
-			  ((ceil(sy / 100.) - (sy / 100.)) * distsinangle));
+		dely = fabs((ceil(sy) - sy) * distsinangle);
 	    else if (sinangle < 0.) {
-		dely =
-		    floor(fabs
-			  ((floor(jp / 100.) - (sy / 100.)) * distsinangle));
+		dely = fabs((floor(sy) - sy) * distsinangle);
 	    mindel = min(delx, dely);
@@ -953,17 +938,14 @@
 double searching()
-    double z2;
-    double curvature_diff;
-    int succes = 1;
     if (zp == UNDEFZ)
 	return 0;
     while (1) {
-	succes = new_point();
+    double z2;
+    double curvature_diff;
-	if (succes != 1) {
+	if (new_point() != 1) {
 	    break;
