[GRASS-dev] Re: [GRASS-SVN] r50806 -
grass/branches/develbranch_6/vector/lidar/v.surf.bspline
Markus Neteler
neteler at osgeo.org
Tue Feb 14 02:12:44 EST 2012
On Tue, Feb 14, 2012 at 12:34 AM, <svn_grass at osgeo.org> wrote:
> Author: hamish
> Date: 2012-02-13 15:34:14 -0800 (Mon, 13 Feb 2012)
> New Revision: 50806
> Modified:
> grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c
> Log:
> change default lambda_i to 0.01 before it ruins any more results (see #1088; setting it to '1' was apparently a mistake as seen by the range of values tested for the cross-validation)
Sounds like a backport candidate? (didn't check the code...)
Markus
