[GRASS-dev] [GRASS GIS] #1576: r.in.poly broken by window split
trac at osgeo.org
Tue Feb 14 22:42:22 EST 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.in.poly, Rast_set_window() | Platform: All
Cpu: All |
r.in.poly was missed during the split window transition (r42876) and now
exits with an error. (previously there was a suppressed-by-the-module
warning)
ERROR: Output window changed while maps are open for write
a simple change in the row paging code of Rast_set_window() to
Rast_set_output_window() in r.in.poly/raster.c didn't help; any advice on
how the input/output split windows now work? the doxygen lib fn comments
briefly explain the what, but not the why of the design or how you're
supposed to use it.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1576>
