[GRASS-dev] how to deal with a python keyword as a module option
name?
Glynn Clements
glynn at gclements.plus.com
Wed Feb 15 16:53:04 EST 2012
Hamish wrote:
> r.resamp.bspline uses 'lambda' as a command line parameter name, but when
> you try to use it with grass.run_command() you get an error as lambda is
> a python reserved keyword. How to work around that?
Prepend an underscore to the name, i.e.:
grass.run_command('r.resamp.bspline', _lambda = ...)
