[GRASS-dev] Re: [GRASS GIS] #1522: dbm_base.py fails with
multilayer maps
trac at osgeo.org
Thu Feb 16 19:47:55 EST 2012
#1522: dbm_base.py fails with multilayer maps
Reporter: artegion | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.2 RCs
Keywords: | Platform: All
Cpu: All |
Old description:
> map 'test' has two layers
> Layer=1 Category=20 Table=net_table
> Layer=2 Category=8 Table=links
> Traceback (most recent call last):
> File "c:/osgeo4w/usr/src/grass-6.4.2RC2/dist.i686-pc-
> mingw32/etc/wxpython/gui_modules/mapdisp_window.py", line
> 1017, in MouseActions
> 1207, in OnLeftUp
> mingw32/etc/wxpython/gui_modules/mapdisp.py", line 1382, in
> QueryVector
> mingw32/etc/wxpython/gui_modules/dbm_dialogs.py", line 102,
> in __init__
> mingw32/etc/wxpython/gui_modules/dbm_dialogs.py", line 360,
> in UpdateDialog
> File
> "C:\Programmi\Grass\etc\wxpython\gui_modules\dbm_base.py",
> line 109, in SelectByPoint
> if self.tables[table][key]['ctype'] != types.StringType:
> KeyError
> 'STATUS'
> v.what works fine
> >> ret = grass.read_command('v.what',
> quiet = True,
> flags = 'ag',
> map = 'test',
> east_north = '60.0,70.0',
> distance = '1.0')
> >> ret
> East=60
> North=70
> Map=test
> Mapset=piacenza
> Type=Line
> Id=20
> Length=20.000000
> Layer=1
> Category=20
> Driver=sqlite
> Database=d:\gis_db\gauss-boaga\test_sqlite.db
> Table=net_table
> Key_column=cat
> cat=20
> net=
> Layer=2
> Category=8
> Driver=sqlite
> Table=links
> Key_column=cat
> cat=8
> ID=12
> LTYPE=1
> NODE1=12
> NODE2=13
> LENGTH=5280
> DIAMETER=10
> ROUGHNESS=100
> MLOSS=0
> STATUS=Open
> PARAMETERS=
> TYPE=
> SETTINGS=
> TAG=ID12
> but grass.vector_what puts Layer 2 attributes into Layer 1
> >>data = grass.vector_what(map = 'test',coord = (60.0, 70.0), distance =
> 1.0)
> >>data
> [{'Category': 20,
> 'Map': 'test',
> 'Layer': 1,
> 'Key_column': 'cat',
> 'Database': 'd:\\gis_db\\gauss-boaga\\test_sqlite.db',
> 'Mapset': 'piacenza',
> 'Driver': 'sqlite',
> 'Length': '20.000000',
> 'Attributes': {'STATUS': 'Open',
> 'LTYPE': '1',
> 'PARAMETERS': '',
> 'DIAMETER': '10',
> 'SETTINGS': '',
> 'MLOSS': '0',
> 'cat': '8',
> 'LENGTH': '5280',
> 'TAG': 'ID12',
> 'NODE1': '12',
> 'NODE2': '13',
> 'TYPE': '',
> 'ID': '12',
> 'ROUGHNESS': '100'},
> 'Table': 'net_table',
> 'Type': 'Line',
> 'Id': 20}]
New description:
1207, in OnLeftUp
QueryVector
in __init__
in UpdateDialog
File
KeyError
'STATUS'
v.what works fine
quiet = True,
flags = 'ag',
map = 'test',
distance = '1.0')
>> ret
East=60
North=70
Map=test
Mapset=piacenza
Type=Line
Id=20
Length=20.000000
Layer=1
Category=20
Driver=sqlite
Table=net_table
Key_column=cat
cat=20
net=
Layer=2
Category=8
Driver=sqlite
Table=links
Key_column=cat
cat=8
ID=12
LTYPE=1
NODE1=12
NODE2=13
LENGTH=5280
DIAMETER=10
ROUGHNESS=100
MLOSS=0
STATUS=Open
PARAMETERS=
TYPE=
SETTINGS=
TAG=ID12
1.0)
>>data
[{'Category': 20,
'Map': 'test',
'Layer': 1,
'Driver': 'sqlite',
'LTYPE': '1',
'PARAMETERS': '',
'DIAMETER': '10',
'SETTINGS': '',
'MLOSS': '0',
'cat': '8',
'LENGTH': '5280',
'TAG': 'ID12',
'NODE1': '12',
'NODE2': '13',
'TYPE': '',
'ID': '12',
'Type': 'Line',
'Id': 20}]
Comment(by hamish):
verbatim formatting applied to ticket description.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1522#comment:2>
