[GRASS-dev] Re: [GRASS GIS] #1576: r.in.poly broken by window split
GRASS GIS trac at osgeo.org
Thu Feb 16 20:36:14 EST 2012
 Reporter:  hamish                                      |       Owner:  grass-dev@…
     Type:  defect                                      |      Status:  new
 Priority:  normal                                      |   Milestone:  7.0.0
Component:  Raster                                      |     Version:  svn-trunk
 Keywords:  r.in.poly, i.topo.corr, Rast_set_window(),  |    Platform:  All
      Cpu:  All                                         |
Comment(by glynn):
 Replying to [ticket:1576 hamish]:
 > any advice on how the input/output split windows now work?
 The input window determines the number of rows and columns for
 Rast_get_row() etc, i.e. the valid range for the "row" parameter, and the
 number of elements in the "buf" array.
 The output window determines the number of rows and columns for
 Rast_put_row() etc, i.e. the number of times it should be called ("put"
 operations don't have a "row" parameter) and the number of elements in the
 "buf" array.
 For most modules, the input and output windows should be the same, but
 e.g. r.resamp.* will typically use split windows.
 The rationale was that the old mechanism was inefficient. It would change
 the window twice for each row of output (set "read" window, read rows, set
 "write" window, write row). Each change caused the column mapping to be
 recalculated for each input map. With split windows, there are separate
 windows for input maps and output maps, eliminating the need to change
 back and forth between input and output windows. The column mapping is
 calculated when a map is opened and never changes. Attempting to change
 the input window while any input maps are open generates an error, as does
 attempting to change the output window while any output maps are open.
 Also, certain functions assume the existence of a single window, e.g.
 Rast_get_window(), Rast_window_{rows,cols}(). These functions still exist,
 and work so long as the windows aren't split (i.e. neither
 Rast_set_input_window() nor Rast_set_output_window() have been called, or
 the windows have since been joined by calling Rast_set_window()), but will
 generate an error if the windows are split. If the windows are split, the
 code must use e.g. Rast_get_input_window(), Rast_input_window_rows() etc
 to read the appropriate window.
 The "split window" design eliminates the most common reason for changing
 the window while maps are open, although there may be cases it doesn't
 cover (e.g. reading multiple input maps at different resolutions won't
 work). If we need to support that, there are a number of possible
 solutions.
 One is to store the current window in the fileinfo structure whenever the
 column mapping is created, check that it matches the current window
 whenever Rast_read_row() etc is called, and either re-generate it or
 generate an error if it differs. This avoids having to needlessly re-
 calculate the column mapping for all input maps on every set-window
 operation, but requires a window comparison (which probably needs some
 tolerance for comparing floating-point fields) for each get-row operation.
 Another is to allow each map to have a separate window, set from the
 current window when the map is opened. The main drawback is that
 Rast_window_rows() etc become meaningless. We would need to add yet
 another "level" of window splitting, so you'd have: single window,
 read/write windows, per-map windows.
 As usual, the main problem isn't implementation, but design and ensuring
 that existing code doesn't silently break (the current implementation
 should ensure that any breakage results in a fatal error).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1576#comment:3>
