[GRASS-dev] [GRASS GIS] #1580: wxGUI crashes when editing script that has been launched at least once
GRASS GIS trac at osgeo.org
Fri Feb 17 04:08:55 EST 2012
 Reporter:  mlennert              |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  normal                |   Milestone:  6.5.0
Component:  wxGUI                 |     Version:  unspecified
 Keywords:  wxGUI, script, crash  |    Platform:  Linux
      Cpu:  Unspecified           |
 - Take any script, such as
 #! /bin/bash
 echo "running script"
 r.to.vect input=myroads output=myroads
 v.select ainput=roadsmajor binput=censusblk_swwake output=selected_roads
 operator=within
 - Launch it using Launch script in the File menu of the wxGUI.
 - Open the script file in any editor (I tried vi and gedit) and save it
 again.
 => wxGUI crashes with the following error message appearing in the
 terminal:
 Gtk:ERROR:/build/buildd-
 gtk+2.0_2.20.1-2-i386-TNeM25/gtk+2.0-2.20.1/gtk/gtkfilesystemmodel.c:746:gtk_file_system_model_sort:
 assertion failed: (r == n_visible_rows)
 A backtrace is attached.
 This happens in trunk, grass65 and grass64svn
Ticket URL: <http://trac.osgeo.org/grass/ticket/1580>
