[GRASS-dev] Re: [GRASS GIS] #1587: GRASS 7 manual: index.html not
generated any more
trac at osgeo.org
Thu Feb 23 15:42:03 EST 2012
#1587: GRASS 7 manual: index.html not generated any more
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 7.0.0
Component: Docs | Version: svn-trunk
Resolution: fixed | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment(by glynn):
Replying to [comment:2 neteler]:
> Hence the implications of r49908 are unclear to me.
r49908 moved the destination directory for manual pages. It omitted a
necessary change for "make bindist" (which was fixed in r50818), but
appears to be otherwise complete. man/Makefile uses MANDIR which is
derived from MANBASEDIR which was changed in r49908, so doesn't require
any changes.
In spite of the name, the "man" directory in the GRASS source tree relates
mainly to the HTML manual pages. It contains the GRASS logo images, the
CSS stylesheet, and the Python scripts to build the various HTML indices.
Both the HTML-format and nroff-format manual pages are normally built from
the module's Makefile, although man/Makefile will generate any nroff-
format pages which are missing. Originally, the nroff-format manual pages
were all generated by man/Makefile, but adding it to the standard "html"
target ensures that any errors in the <module>.html file will show up if
the developer runs "make" in the module directory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1587#comment:4>
