[GRASS-dev] Re: GRASS 7 compiled from source on Ubuntu 11.04, error with 3-D view.
Isaac Ullah isaac.ullah at asu.edu
Fri Feb 24 17:19:46 EST 2012
Actually, now that I am thinking about it, this may be related to an
ongoing NVIZ problem that I have had since moving to Ubuntu 11.03.
Essentially, what happens is that NVIZ only *sort of* works in that I can
get it to load up and display a map, but as soon as i touch any of the
controls with the mouse, the map canvas goes blank. I can see glimpses of
the map in coarse mode as if I rotate the view or zoom perspective or raise
the height, but the display always goes back blank as soon as I stop
moving. Sometimes the display DOES come back if I briefly click the eye
arrow and then don't move the mouse, but this is only temporary. This
happens on all three versions of grass I have installed (6.4.1 from ubuntu
GIS repository, 6.4.2 from SVN snapshot binary, and 7.0 compiled from
source). This is *not* the same exact issue with the 3D map display in 7.0,
which just doesn't even load through, but it *is* an error I have been
having with 3D display of maps in GRASS in general...
~Isaac
On Fri, Feb 24, 2012 at 2:34 PM, Isaac Ullah <isaac.ullah at asu.edu> wrote:
> Hi all,
>   After some time I've decided to start testing latest devel versions of
> GRASS on Ubuntu again. I have just today successfully compiled this week's
> SVN snapshot on Ubuntu 11.04 64-bit with the following configuration
> options: CFLAGS="-g -Wall" ./configure --with-cxx --with-freetype=yes
> --with-postgres=no --with-sqlite=yes
> --with-tcltk-includes=/usr/include/tcl8.5
> --with-freetype-includes=/usr/include/freetype2
> --with-python=/usr/bin/python-config --with-wxwidgets=yes --with-nls
> --enable-largefile --with-proj-share=/usr/share/proj --enable-64bit
> --with-libs=/usr/lib64 --with-gdal=/usr/bin/gdal-config
> There was one error upon compile in the NVIS directory where StdCmap.h was
> not found. It was because libxmu-dev was not installed. Apparently libxmu
> is a necessary component for NVIS to compile, but it is strangely not
> listed as a necessary component on the requirements page (
> http://grass.osgeo.org/grass70/source/snapshot/REQUIREMENTS.html).
> Anyhow, after I installed libxmu-dev then GRASS 7 compiles with no errors.
> So far, most basic functionality seems to work, except for the 3-D view in
> the map display. I get the following errors when I try to use it:
> Starting 3D view
> mode...
> Exception in thread Thread-5:
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/threading.py", line 552, in
> __bootstrap_inner
>     self.run()
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/nviz/mapwi
> ndow.py", line 62, in run
>     self._display = wxnviz.Nviz(self.log, self.progressbar)
>   File
> "/usr/local/grass-7.0.svn/etc/gui/wxpython/nviz/wxnviz.py",
> line 104, in __init__
>     self.data_obj = nv_data()
> NameError: global name 'nv_data' is not defined
> Exception
> AttributeError
> "'Nviz' object has no attribute 'data'"
>  in
> <bound method Nviz.__del__ of <nviz.wxnviz.Nviz object at
> 0x53f3390>>
>  ignored
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/to
> olbars.py", line 229, in OnSelectTool
> self.parent.AddNviz()
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/fr
> ame.py", line 296, in AddNviz
> Map = self.Map, tree = self.tree, lmgr = self._layerManager)
> ndow.py", line 152, in __init__
> self.decoration = self.nvizDefault.SetDecorDefaultProp(type
> = 'arrow')
>   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/nviz/works
> pace.py", line 330, in SetDecorDefaultProp
> UserSettings.Get(group = 'nviz', key = 'arrow', subkey =
> 'color')[:3])
> TypeError
> %d format: a number is required, not str
> Is this a known issue? Or something ubuntu-specific? It looks like an
> error with a specific variable that's being called in a python script
> before it is assigned. Any ideas on what to tinker with to get it working?
> Regards,
> Isaac I Ullah, M.A.
> Archaeology PhD Candidate,
> ASU School of Evolution and Social Change
> Research Assistant,
> Mediterranean Landscape Dynamics Project
> ullah at archaeologist.com
> http://www.public.asu.edu/~iullah
Isaac I Ullah, M.A.
Research Assistant,
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120224/b1420801/attachment-0001.html
