[GRASS-dev] Re: [GRASS GIS] #1597: r.topidx ERROR current region resolution
GRASS GIS trac at osgeo.org
Mon Feb 27 15:35:34 EST 2012
 Reporter:  madi      |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.5.0
Component:  Raster    |     Version:  svn-develbranch6
 Keywords:  r.topidx  |    Platform:  Linux
      Cpu:  x86-64    |
Comment(by neteler):
 The code in question is in file_io.c:
     if (window.ew_res < inhead.ew_res || window.ns_res < inhead.ns_res)
         G_fatal_error(_("Current region resolution [%.2fx%.2f] lower than
 input map resolution [%.2fx%.2f]! Needs to be at least identical or the
 current region resolution lower than the input map resolution"),
                       window.ew_res, window.ns_res, inhead.ew_res,
                       inhead.ns_res);
 I suspect that GRASS_EPSILON should be used here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1597#comment:1>
