[GRASS-dev] Re: [GRASS GIS] #1597: r.topidx ERROR current region
resolution
trac at osgeo.org
Mon Feb 27 17:51:15 EST 2012
#1597: r.topidx ERROR current region resolution
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: svn-develbranch6
Keywords: r.topidx | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
ok so the two grids don't match (your dem map is not on multiples of 20m,
its grid is offset), and it is being resampled. what does the full r.info
say? (everything between the Type of map: and Range of data: lines)
was it a self-made DEM or did you import it from some 3rd party source?
(ie can you remake it on a cleaner grid without loss?)
also try "g.region -p rast=dem" before r.topidx so that the region and the
map perfectly align the map's (offset) grid.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1597#comment:5>
