[GRASS-dev] Speeding up v.out.ogr (again)
Benjamin Ducke benducke at fastmail.fm
Wed Feb 29 02:23:04 EST 2012
Dear Devs,
A while ago, I submitted a small patch for v.out.ogr
that moves the SQL SELECT out of the mk_att() function,
so that this costly operation does not have to be
performed multiple times:
http://lists.osgeo.org/pipermail/grass-dev/2011-January/053150.html
Looking at 6.4.2 and 6.5 SVN copies of v.out.ogr,
I see that SQL SELECT is still (again?) in mk_att(), with
this comment (line 1053):
  /* Fetch all attribute records for cat <cat> */
  /* opening and closing the cursor is slow,
   * but the cursor really needs to be opened for each cat separately */
Is this because of GRASS maps that have more than one
attribute table connection?
If so, then I suggest putting in a condition, so that those
GRASS maps that have just one attribute table can perform
the SQL SELECT outside of mk_att(). Otherwise, we punish
all GRASS users with extremely slow export speed, even though
most of them might not even use multi-table attributes in
their projects. The difference in my test was something like
factor 500!
Best,
Ben
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
  benducke AT fastmail.fm
