#1527: vector projection over wrapping boundary is split
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.2
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment(by mmetz):
Please try trunk r50023. There is a new option to disable longitude
wrapping directly in the proj4 library
Disabling longitude wrapping could (should?) be the default since usually
there is no difference, and if errors occur, the default wrapping needs to
be disabled in proj4 in order to preserve vector topology.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1527#comment:8>
