[GRASS-dev] Re: [GRASS GIS] #1526: "Diplay/update attributes" can freeze GUI
GRASS GIS trac at osgeo.org
Tue Jan 3 08:08:27 EST 2012
 Reporter:  artegion  |       Owner:  martinl
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.2
Component:  wxGUI     |     Version:  6.4.2 RCs
 Keywords:            |    Platform:  MSWindows XP
      Cpu:  x86-64    |
Comment(by martinl):
 Replying to [comment:4 artegion]:
 > Yes, with 6.5 it works.
 it's just the coincidence, in G65 simply command which doesn't terminate
 is not called. The SQL statement is checked first and then the command
 (`db.execute sql=`) is launched. The problem is that the process launched
 doesn't terminate in this case.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:5>
