[GRASS-dev] r.viewshed -memory problem
Jan Trochta j.trochta at gmail.com
Tue Jan 10 07:03:20 EST 2012
Hi Folks,
I am try to use GRASS7 SVN on win 7. I tested new modul r.viewshed on
large dataset. But some problem with memory.
not shure if it is my mistake or bug.
Jan Trochta
r.viewshed -e --overwrite --verbose input=STRomy na boubin output=pk
coordinate=-803821.575747913,-1158866.72289775 max_dist=1500
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
Nodata value set to -1.#QNAN0
rows=14293, cols=12816, total = 183179088
In-memory memory usage is 18318011328 B (17469 MB), 			max mem
allowed=524288000 B(500MB)
*****  EXTERNAL_MEMORY MODE  *****
Intermediate files will not be deleted 		              in case of
abnormal termination.
To save space delete these files manually!
Estimated size active structure:
(key=64, ptr=4, total node=80 B)
Total= 1143440 B
Start sweeping.
Computing events ...
Sorting events...
MM warning: limit=524288000B. allocating 261881248B.  limit
exceeded by 2520B.
exceeded by 2598B.
exceeded by 2676B.
exceeded by 2754B.
exceeded by 2832B.
exceeded by 2910B.
exceeded by 2988B.
exceeded by 3066B.
exceeded by 3144B.
exceeded by 3222B.
exceeded by 3300B.
exceeded by 3378B.
exceeded by 3456B.
exceeded by 3534B.
exceeded by 3612B.
exceeded by 3690B.
exceeded by 3768B.
exceeded by 3846B.
exceeded by 3924B.
exceeded by 4002B.
exceeded by 4080B.
exceeded by 4158B.
exceeded by 4236B.
exceeded by 4314B.
exceeded by 4392B.
ami_single_temp_name: mktemp failed: : File exists
Assertion failed: 0, file ami_stream.cpp, line 97
This application has requested the Runtime to terminate it
in an unusual way.
Please contact the application's support team for more
information.
(Tue Jan 10 12:57:51 2012) Command finished (17 min 22 sec)
