[GRASS-dev] wingrass change current working directory
Markus Metz
markus.metz.giswork at googlemail.com
Fri Jan 13 17:50:44 EST 2012
On Thu, Jan 12, 2012 at 4:38 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> it would be great to have that - it would make it much easier to manage homework results for all the students using GRASS in class, especially when they are just starting,
Added in trunk r50167. Save the user-defined current working directory
in a GRASS environment variable?
Markus M
> Helena
> On Jan 12, 2012, at 9:33 AM, Markus Metz wrote:
>> Would there be interest to have in the wxGUI the possibility to change
>> the current working directory for a GRASS session? By default this is
>> under windows the documents and settings folder of the current user,
>> but project-related data and output may well be somewhere else. This
>> "somewhere else" could be made the current working directory as far as
>> the wxGUI is concerned (similar to what R has for windows). I have a
>> patch to do that in the wxGUI in my local copy and would like to know
>> if there is general interest in this little patch.
>> Markus M
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
