[GRASS-dev] Re: [GRASS GIS] #1527: vector projection over wrapping
boundary is split
trac at osgeo.org
Sat Jan 14 22:02:12 EST 2012
#1527: vector projection over wrapping boundary is split
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.2
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment(by hamish):
if the raster library can handle this situation automatically and cleanly
for both the 0-360 and -180-180 cases, then why can't the vector lib be
taught do the same? forcing the user to manually do a task which should be
figured out automagically by the software seems less than ideal.
is the real problem not actually the literal numbers stored in the data
file, but rather a failure of the vector modules and display modules to
wrap LL when needed, or the vector reading library functions for not
automatically cleansing to within range?
(aka get rid of any unqualified Pythagorean shortcuts in the code, and
have libraries swap over geodesic calculations if a LL location is
detected)
Hamish (170E)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1527#comment:13>
