[GRASS-dev] Re: Copyright and license issue
Jarek Jasiewicz
jarek.jasiewicz at gmail.com
Sun Jan 15 13:00:16 EST 2012
On 01/15/2012 07:36 AM, Roger Bivand wrote:
> Hamish<hamish_b<at> yahoo.com> writes:
>> Jarek wrote:
>>> Ok, it explains everything. So if I want to publish code with any GPL
>>> privileges granded, but keep code integrity in one official place which
>>> I can put in paper as link to OFFICIAL source code, with guarantee that
>>> it won't be accidentaly changed, I must put it outside GRASS repository?
>>> Right?
>> if you want to delay releasing under the GPL until you have your article
>> published, then you would have to wait to put it in the grass addons repo
>> too, which is open to GPL-compatible code only. (as per rfc2)
> I think that Jarek's concern is that someone other than the add-on developers
> have commit rights. In R, this is handled by having an add-on incubator called
> R-Forge https://r-forge.r-project.org/, which can also be used for installation,
> but where the project intiator(s) are the only non-admins with commit rights.
yes, it would be really nice to have restricted area for incubated projects.
I also do not think that it is not GPL compatible. Everybody can
download, change and publish modified code except that original
repository may be changed by limited group of people.
jarek
> When packages are released to CRAN, installation becomes somewhat easier. This
> might work here if OSGeo had a *-Forge facility, part of which could be used for
> add-ons for GRASS. The point about R-Forge rather than CRAN is that the R-Forge
> SVN lets people collaborate and try things out before the add-ons reach
> usability (the classes start at Planning, then pre-Alpha, and so on using
> Trove). So until the add-on developers release it, no-one they haven't nominated
> can commit. It looks as though the -install argument takes a complete URL, so a
> miminal *-Forge would make a nightly tarball that could be installed.
> Of course, someone might download the add-on source, modify it, and distribute
> that modified version, but I'm not sure that this was the underlying issue here,
> rather that the public add-on SVN server has potentially many commit permissions.
> Roger
>> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
