[GRASS-dev] Re: v.report (in wingrass65svn): ERROR: There is a table connected to input vector map 'c_ele_basin@g7', but there are no categories present in the key column 'cat'.
Helmut Kudrnovsky hellik at web.de
Sun Jan 15 17:36:26 EST 2012
the same with the geology-vector of the nc-sample-data-set:
v.report map=geology at PERMANENT option=area
Zeige Typ/Name der Spalten der Datenbank des Layers 1:
Die Eingabedatei wurde zweimal angegeben.
the input is there twice.
ERROR: There is a table connected to input vector map 'geology at PERMANENT',
but there are no categories present in the key column 'cat'. Consider using
v.to.db to correct this.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-report-in-wingrass65svn-ERROR-There-is-a-table-connected-to-input-vector-map-c-ele-basin-g7-but-th-tp7190874p7190887.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
