[GRASS-dev] Re: [GRASS GIS] #1535: winGRASS g.extension.py problems
    trac at osgeo.org
    Mon Jan 16 06:12:23 EST 2012
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.2
Component:  wxGUI        |     Version:  6.4.2 RCs
 Keywords:  g.extension  |    Platform:  MSWindows XP
      Cpu:  x86-32       |
Comment(by hamish):
 The GRASS program path: [C:/Programmi/GRASS 6.4.SVN] contains a space. The
 build which follows will likely fail.
 The specified install path: [/c/Documents and
 Settings/netelerm.INTRA/.grass6/addons] contains a space. The build which
 The path to your GIS data: [C:\Documents and
 Settings\netelerm.INTRA\Documenti\grassdata] may contain a space. The
 afaik those warning messages only come from the shell script version(??).
 I did not want to make running it with paths containing spaces fatal in
 case somebody wanted to work on improving the make+spaces situation, but
 maybe we should to avoid lots of bug reports. I expect windows users to
 mostly spend their time in the wxgui so unless they are used to the unix
 version first they'd usually be steered to Martin's pre-built download
 modules. shrug.
 wrt wget, is it not packaged?? I thought it was. or maybe curl is shipped
 instead? if wget is shipped maybe there's a path problem?
 the python g.extension.py is in 6.4svn (it is what is shown in your
 screenshot). sorry I can't be much help with the .py file association
 errors.
 `g.extension ext=database` ? is that to download and build all db addon
 modules??
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1535#comment:2>
