[GRASS-dev] Re: [GRASS GIS] #1536: add EPSG:900913 to location
wizard
trac at osgeo.org
Mon Jan 16 17:55:29 EST 2012
#1536: add EPSG:900913 to location wizard
Reporter: timmie | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.2
Component: Projections/Datums | Version: 6.4.2 RCs
Keywords: google projection, epsg | Platform: All
Cpu: Unspecified |
Changes (by neteler):
* platform: MSWindows XP => All
Comment:
I would note that it is not the official code:
tail -3 /usr/share/proj/esri.extra
# Chris' funny epsgish code for the google mercator
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs <>
The fact that 900913 exists is AFAIK historically: to get +nadgrids=@null
into a code. For subsequent history, see Hamish's comment above.
See also:
http://trac.osgeo.org/openlayers/wiki/SphericalMercator
"SphericalMercator and EPSG aliases
The SphericalMercator projection in OpenLayers uses code epsg:900913. When
Google started to use the SphericalMercator projection, a corresponding
EPSG
code did not yet exist, so a temporary code '900913' (notice the
resemblance
to the word 'google') was invented. Many other services, such as
OpenStreetMap,
Bing and Yahoo are now also using the same projection, but are not
necessarily
supporting the use of code EPSG:900913. Other codes, such as EPSG:3857 and
EPSG:102113 were invented. Today, there is an officially registered EPSG
code
3857 whose projection is identical to EPSG:900913.
(http://www.epsg-registry.org/export.htm?gml=urn:ogc:def:crs:EPSG::3857)."
I would suggest to support the official code rather than the inofficial
one
which may disappear since superceeded.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1536#comment:2>
