[GRASS-dev] Re: [GRASS GIS] #428: g.proj -c defines wrong default values
GRASS GIS trac at osgeo.org
Tue Jan 17 05:22:22 EST 2012
 Reporter:  martinl                      |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  major                        |   Milestone:  6.4.0
Component:  Default                      |     Version:  6.4.0 RCs
 Keywords:  projection, create location  |    Platform:  All
      Cpu:  All                          |
Comment(by hamish):
 close as invalid? (the math needs some sort of default coefficient if it
 is to run; if that is to be considered an error it needs to be a request
 in the proj4 tracker, g.proj isn't involved in the projection logic at
 that level)
Ticket URL: <https://trac.osgeo.org/grass/ticket/428#comment:5>
