[GRASS-dev] Re: [GRASS GIS] #1438: g.remove cannot remove vector
map because of
space in DB layer name (was: g.remove cannot remove vector map)
trac at osgeo.org
Tue Jan 17 07:26:43 EST 2012
#1438: g.remove cannot remove vector map because of space in DB layer name
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone:
Component: Database | Version: 6.4.1
Resolution: | Keywords: dbln, g.remove, layer name
Platform: MSWindows 7 | Cpu: Unspecified
Changes (by hamish):
* keywords: => dbln, g.remove, layer name
* component: Vector => Database
Comment:
your vector/pointdata/dbln file looks like this:
1/raw.TxDOT crash pointdata cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
the layer name (raw.TxDOT crash) is not allowed to have a space in it with
GRASS 6. In GRASS 7 the separator becomes a "|" instead of a space so they
are allowed there. GRASS 6 can read dbln files with "|" as the fields
separator, so you might try to edit it by hand to:
1/raw.TxDOT crash|pointdata|cat|$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/|dbf
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1438#comment:3>
