[GRASS-dev] Re: [GRASS GIS] #1139: v.report has a problem (only via
OSGEO4W package)
trac at osgeo.org
Tue Jan 17 13:14:30 EST 2012
#1139: v.report has a problem (only via OSGEO4W package)
Reporter: naokiueda | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Vector | Version: 6.4.2 RCs
Keywords: wingrass, v.report, osgeo4w | Platform: MSWindows Vista
Cpu: x86-32 |
Changes (by hellik):
* priority: normal => critical
* platform: Unspecified => MSWindows Vista
* version: 6.4.0 RCs => 6.4.2 RCs
* cpu: Unspecified => x86-32
Comment:
tested with '''osgeo4w-wingrass6.4.2RC3''' (WinVista-32bit-box) and nc-
sample-dataset:
v.report map=geology at PERMANENT option=area
Zeige Typ/Name der Spalten der Datenbank des Layers 1:
Show type/name of database's columns of layer 1:
Die Eingabedatei wurde zweimal angegeben.
The input is given twice.
ERROR: There is a table connected to input vector map 'geology at PERMANENT',
but there are no categories present in the key column 'cat'. Consider
using v.to.db to correct this.
(Tue Jan 17 18:57:00 2012) Befehl ausgeführt (5 sec)
D2/3: load_table_head(): tab = 20,
C:\gisdata\grassdata\nc_spm_08\PERMANENT\dbf\\geology.dbf
D2/3: ncols = 8
D2/3: DBFFieldType 1
D3/3: add_column(): tab = 20, type = 2, name = cat, width =
11, decimals = 0
D2/3: DBFFieldType 2
D3/3: add_column(): tab = 20, type = 3, name = onemap_pro,
width = 20, decimals = 6
D3/3: add_column(): tab = 20, type = 3, name = PERIMETER,
D3/3: add_column(): tab = 20, type = 2, name = GEOL250_,
width = 11, decimals = 0
D3/3: add_column(): tab = 20, type = 2, name = GEOL250_ID,
D2/3: DBFFieldType 0
D3/3: add_column(): tab = 20, type = 1, name = GEO_NAME,
width = 6, decimals = 0
D3/3: add_column(): tab = 20, type = 3, name = SHAPE_area,
D3/3: add_column(): tab = 20, type = 3, name = SHAPE_len,
D2/3: save_table 0
D2/3: save_table 1
D2/3: save_table 2
D2/3: save_table 3
D2/3: save_table 4
D2/3: save_table 5
D2/3: save_table 6
D2/3: save_table 7
D2/3: save_table 8
D2/3: save_table 9
D2/3: save_table 42
D2/3: save_table 43
D2/3: save_table 44
D1/3: Vect_close(): name = geology, mapset = PERMANENT,
format = 0, level = 2
D1/3: close history file
the input is given twice.
D1/3: Vect_open_old(): name = geology at PERMANENT mapset=
PERMANENT update = 0
D2/3: Vect_cidx_open(): name = geology mapset= PERMANENT
D3/3: dig_cidx_init()
D3/3: dig_read_cidx()
D3/3: Cidx header: file version 5.0 , supported from GRASS
version 5.0
D3/3: byte order 0
D3/3: header size 9
D1/3: V1_open_old_nat(): name = geology mapset = PERMANENT
D2/3: Coor header: file version 5.1 , supported from GRASS
version 5.1
D2/3: byte order 0
D2/3: header size 14
D2/3: with_z 0
D2/3: coor size 9016555
D1/3: get coor info:
C:\gisdata\grassdata/nc_spm_08/PERMANENT/vector/geology/coor
D1/3: Info->size = 9016555, Info->mtime = 1198040780
D1/3: coor size in head = 9016555, real coor file size=
9016555
D2/3: dig_file_load ()
D2/3: requested mode = 2
D2/3: size = 9016555
D2/3: file was not loaded to the memory
D1/3: Vect_open_old(): vector opened on level 2
D1/3: Vect_read_dblinks(): map = geology, mapset = PERMANENT
D3/3: Searching for FID column in OGR DB
D1/3: dbln file:
C:\gisdata\grassdata/nc_spm_08/PERMANENT/vector/geology/dbln
D1/3: dbln: 1 geology cat
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D3/3: Field number <1>, name <(null)>
D3/3: Vect_check_dblink: field 1
D1/3: field = 1 name = (null), table = geology, key = cat,
database = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver =
dbf
D1/3: Dblinks read
D1/3: Vect_Rewind(): name = geology
D1/3: Vect_get_dblink(): link = 0
D3/3: Vect_subst_var(): in =
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, map = geology, mapset
= PERMANENT
D3/3: -> C:\gisdata\grassdata\nc_spm_08\PERMANENT\dbf\
D1/3: V1_close_nat(): name = geology mapset= PERMANENT
D1/3: ret = 1
complete debug=3-report attached.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1139#comment:7>
