[GRASS-dev] Re: [GRASS GIS] #1139: v.report has a problem (only via OSGEO4W package)
GRASS GIS trac at osgeo.org
Tue Jan 17 15:01:36 EST 2012
 Reporter:  naokiueda                    |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  critical                     |   Milestone:  6.4.2
Component:  Vector                       |     Version:  6.4.2 RCs
 Keywords:  wingrass, v.report, osgeo4w  |    Platform:  MSWindows Vista
      Cpu:  x86-32                       |
Comment(by hellik):
 Replying to [comment:10 hamish]:
 > Can you edit the script and change the first line to '#!/bin/sh -x' and
 post the output?
 first line to '#!/bin/sh -x':
 GRASS 6.4.2RC3 (nc_spm_08)> v.report map=geology at PERMANENT option=area
 Zeige Typ/Name der Spalten der Datenbank des Layers 1:
 Die Eingabedatei wurde zweimal angegeben.
 Input file specified two times.
 FEHLER: There is a table connected to input vector map
 'geology at PERMANENT',
         but there are no categories present in the key column 'cat'.
         Consider using v.to.db to correct this.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1139#comment:11>
