[GRASS-dev] Re: [GRASS GIS] #1276: r.null in winGRASS does not work
properly
trac at osgeo.org
Wed Jan 18 06:19:41 EST 2012
#1276: r.null in winGRASS does not work properly
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: 6.4.1 RCs
Keywords: r.null, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by hamish):
a debug message I threw into devbr6 shows that the "5" was making it into
the variable ok.
if you convert streets_speed to a DCELL map from a CELL map:
r.mapcalc "streets_speed.DCELL = double(streets_speed)"
then r.null works as expected.
I strongly suspect the trouble is on this line of r.null/mask.c:
if (change_null && G_is_null_value(rast, data_type))
G_set_raster_value_d(rast, new_null, data_type);
new_null is always sent as DCELL, but data_type changes.
(n.b. for CELL maps the command line value for new_null is laundered into
something CELL compatible by main.c when it is first read in, but only if
you enter a non-integer for null=)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:5>
