[GRASS-dev] Re: [GRASS GIS] #1276: r.null in winGRASS does not work
properly
trac at osgeo.org
Wed Jan 18 21:29:39 EST 2012
#1276: r.null in winGRASS does not work properly
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: 6.4.1 RCs
Keywords: r.null, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by hamish):
when testing this (in XP, where it fails too), to reset the map-to-
be-r.null'd I had been rerunning with the overwrite flag:
v.to.rast streets_wake out=streets_speed use=attr col=SPEED --o
it happened that I got an error that it could not move the created map
from .tmp/ into the main mapset dir, presumably because some part of it
was still an open file. I though to save that for another bug report as it
seemed to only happen the 4th or 5th time overwriting it, but maybe it is
relevant or a sign some more general problem.
Hamish
(offline/in the field until next week or so)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:7>
