[GRASS-dev] Re: [GRASS GIS] #1539: bug in v.net.components
trac at osgeo.org
Fri Jan 20 03:18:15 EST 2012
Reporter: gojira | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: Vector | Version: unspecified
Keywords: net | Platform: Linux
Cpu: x86-32 |
Comment(by mmetz):
Replying to [ticket:1539 gojira]:
> the command v.net.components does not work properly from the version
6.5. I tried also the version 7.0 of grass but only with actual stable
version 6.4 I obtained the right result with lines that goes from one
multi-junction node to another.
This is strange because the code for v.net.components is identical in
6.4.2 and 6.5, also the code for the neta library used by this module.
Do you have an example to reproduce?
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1539#comment:1>
