[GRASS-dev] Vect_get_area_boundaries() and negative ids
Martin Landa
landa.martin at gmail.com
Fri Jan 20 06:56:56 EST 2012
2012/1/20 Markus Metz <markus.metz.giswork at googlemail.com>:
>> Similar for Vect_get_isle_boundaries() or am I wrong?
> The sign indicates in which direction the boundary should be read
> (negative for backward). Therefore negative ids are correct.
OK, I added note to the API manual in r50315.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
