[GRASS-dev] Map_info with_z
Markus Metz
markus.metz.giswork at googlemail.com
Sat Jan 21 09:35:29 EST 2012
Martin Landa wrote:
> Hi all,
> currently dimension of vector map is stored in three different places (vlib)
> Map->plus.spidx_with_z (Plus_head) -> spatial index
That is coming from GRASS 5 and used as a safety check that the
spatial index has the same dimensions like the coordinates. It can
probably be removed.
> Map->plus.with_z (Plus_head) -> topology
Needed by diglib, because diglib functions get only Map->plus, not Map itself.
> Map->head.with_z (Map_info) -> head
Needed for reading and writing coordinates and if no topology is
available or requested (e.g. v.info, v.surf.*).
Markus M
