[GRASS-dev] v.info: projection info wrong
Markus Neteler
neteler at osgeo.org
Sat Jan 21 13:31:34 EST 2012
GRASS 6.4.2svn (piemonte_utm32_wgs84):/grassdata > v.info beni_urbanistici
| Layer: beni_urbanistici |
| Mapset: PERMANENT |
| Source date: Sat Jan 21 19:09:31 2012 |
| Type of Map: vector (level: 2) |
| Number of points: 7990 Number of areas: 0 |
| Number of dblinks: 1 |
| Projection: x,y (zone 0) |
| N: 5141441.38439781 S: 4881740.8577152 |
| E: 514815.51117203 W: 317192.39544124 |
--> x,y (zone 0)?
GRASS 6.4.2svn (piemonte_utm32_wgs84):/grassdata > g.region -p
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
The code chunk is
v.info/main.c:
/* this differs from r.info in that proj info IS taken
from the map here, not the location settings */
/* Vect_get_proj_name() and _zone() are typically unset?! */
if (G_projection() == PROJECTION_UTM)
sprintf(line, _(" Projection: %s (zone %d)"),
Vect_get_proj_name(&Map), Vect_get_zone(&Map));
else
sprintf(line, _(" Projection: %s"),
Vect_get_proj_name(&Map));
Any ideas why this fails?
Markus
