[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Mon Jan 23 17:28:57 EST 2012
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 6.4.2
Component: Installation | Version: svn-releasebranch64
Resolution: wontfix | Keywords: wingrass, g.extension, path, installation, addons
Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [comment:41 hellik]:
> Replying to [comment:40 neteler]:
> > AFAIK some improvements have been done in SVN, please retry.
> there is no improvement at the moment for compiling with spaces in path,
but you're informed why the compilation fails:
> g.extension --verbose extension=r.stream.angle
svnurl=https://svn.osgeo.org/grass/grass-addons
> Using WGET for downloading data.
> GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
> The GRASS program path: [c:/Program Files/GRASS 6.4RC1] contains a
space. The build which follows will likely fail.
> Fetching <r.stream.angle> from GRASS-Addons SVN (be patient)...
> A r.stream.angle\tangent.c
> A r.stream.angle\init.c
> A r.stream.angle\main.c
> A r.stream.angle\description.html
> A r.stream.angle\global.h
> A r.stream.angle\seg_line.c
> A r.stream.angle\io.c
> A r.stream.angle\order.c
> A r.stream.angle\Makefile
> Checked out revision 48766.
> Compiling <r.stream.angle>...
> Makefile:12: c:/Program: No such file or directory
> Makefile:12: Files/GRASS: No such file or directory
> Makefile:12: 6.4RC1/include/Make/Module.make: No such file
> or directory
> make: *** No rule to make target
> `6.4RC1/include/Make/Module.make'. Stop.
> ERROR: Compilation failed, sorry. Please check above error messages.
> rm: cannot remove directory `C:\\gisdata\\grassdata/nc_spm_0
> 8/user1/.tmp/6060.0/r.stream.angle': Permission denied
> (Wed Oct 12 19:14:25 2011) Command finished (24 sec)
now there are precompiled addons-binaries available for wingrass. closing
as wontfix.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178#comment:42>
