[GRASS-dev] Re: [GRASS GIS] #1289: wingrass65 - Vector digitizer
not available: Reason: xdr not found
trac at osgeo.org
Mon Jan 23 17:36:04 EST 2012
#1289: wingrass65 - Vector digitizer not available: Reason: xdr not found
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: fixed | Keywords: wingrass, vector, digitizer
Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [ticket:1289 hellik]:
> tested with a self compiled wingrass65 at r45511
> message in the wxgui at startup:
> 3D view mode not available
> Reason: xdr not found.
> Note that the wxGUI's 3D view mode is currently disabled on
> MS Windows (hopefully this will be fixed soon). Please keep
> an eye out for updated versions of GRASS. In the meantime
> you can use "NVIZ" from the File menu.
> Note that the wxGUI's vector digitizer is currently disabled
> (hopefully this will be fixed soon). Please keep an eye out
> for updated versions of GRASS. In the meantime you can use
> "v.digit" from the Develop Vector menu.
> from package.log
> checking for library containing cuserid... no
> checking for xdrmem_create... no
> checking for xdrmem_create in -lsun... no
> checking for xdrmem_create in -lnsl... no
> checking for xdrmem_create in -lrpclib... no
> checking for xdrmem_create in -lxdr... yes
> checking for asprintf... no
> checking for atan... yes
> if I add a vector in the mapdisplay and then open the table attribute
manager, dbf.exe is crashing.
> Helmut
closing ticket after a nearly a year of successfull testing.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1289#comment:1>
