[GRASS-dev] Re: [GRASS GIS] #1117: WinGrass7 - wxgui not starting
GRASS GIS trac at osgeo.org
Tue Jan 24 10:37:14 EST 2012
  Reporter:  hellik           |       Owner:  grass-dev@…
      Type:  defect           |      Status:  reopened
  Priority:  normal           |   Milestone:  7.0.0
 Component:  Packaging        |     Version:  svn-trunk
Resolution:                   |    Keywords:  wingrass, wxgui
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Changes (by mmetz):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Replying to [comment:2 hellik]:
 > closing the ticket after a more than a year successfull testing.
 Bad news: I tested
 http://wingrass.fsv.cvut.cz/grass70/WinGRASS-7.0.SVN-r50400-1-Setup.exe
 and does not work on xp. Exactly nothing happens. When executing the start
 bat files from the windows command line, there seems to be a problem with
 an unquoted path somewhere.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1117#comment:3>
