[GRASS-dev] Re: [GRASS GIS] #1276: r.null in winGRASS does not work
properly
trac at osgeo.org
Tue Jan 24 21:50:34 EST 2012
#1276: r.null in winGRASS does not work properly
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: 6.4.1 RCs
Keywords: r.null, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:10 hamish]:
> From the timestamps (and r.info showing the correct range) I can confirm
that cell_misc/$MAP/null and cell_misc/$MAP/range are updated when running
r.null on Windows XP, but cell/$MAP's timestamp is not updated.
AFAICT, the only way for G_close_cell() to not delete that file and not
print a warning is if G__open_null_write() fails at line 207. But that
should result in the null file not being updated (contrary to my previous
comment, the null file isn't updated in-place; it's handled the same way
as the cell/fcell file).
Otherwise, it should attempt to rename the file, and any failure should
generate a warning. There aren't any return statements in close_new()
between renaming the null file and renaming the cell/fcell file, so I
don't know how this situation can arise.
> bug: close(fd) is called twice, (??)
The first one (line 288) should be removed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:11>
