[GRASS-dev] [GRASS GIS] #1553: path settings to msys on wingrass
trac at osgeo.org
Fri Jan 27 02:35:17 EST 2012
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Default | Version: unspecified
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
Commandline environment is behaving strange on wingrass (likely because of
path setings):
e.g.
sort command ("sort -n -t ','") exits with error message:
"Input file specified two times"
It seems to be a problem of path-settings. See:
http://www.question-defense.com/2010/08/25/windows-7-cygwin-sort-input-
file-specified-two-times
Error occures both when installing GRASS through OSGeo4W-installer and
though QGIS-standalone installer (and with different GRASS versions (6.4.1
and 6.4.2)).
Probably, the path to msys/MINGW is hidden by some Windows settings...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1553>
