[GRASS-dev] Re: [GRASS GIS] #1552: WinGRASS: spaces in pathnames for r.in.aster
GRASS GIS trac at osgeo.org
Fri Jan 27 06:15:38 EST 2012
 Reporter:  Venkat                |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  major                 |   Milestone:  6.4.2
Component:  Shell Scripts         |     Version:  svn-releasebranch64
 Keywords:  wingrass, r.in.aster  |    Platform:  MSWindows 7
      Cpu:  Unspecified           |
Comment(by Venkat):
 The Error Message is as below. The GISDBASE directory is named as
 "GIS DataBase" with a space between GIS and DataBase
 Best, Venka
 r.in.aster input=C:\Aster_Data\PRDAT011.DAT proctype=L1B band=1
 output=ASTET_01_test
 Georeferencing aster image ...
 ERROR 4: `C:\GIS' does not exist in the file system,
 and is not recognised as a supported dataset name.
 Importing into GRASS ...
 ERROR 4: `C:\GIS DataBase/osaka/PERMANENT/.tmp/2724.0.tif'
 Cleaning up ...
 ERROR: Raster map <ASTET_01_test> not found in current mapset
 Done.
 (Fri Jan 27 19:42:30 2012) Command finished (1 sec)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1552#comment:2>
